configure esrp add elrp-poll ports
configure esrp esrpDomain add elrp-poll ports [ports | all]
Description
Configures the ports of an ESRP domain where ELRP packet transmission is requested by ESRP.
Syntax Description
esrpDomain Specifies an ESRP domain name.
ports Specifies list of slots and ports.
all Specifies all ports in the ESRP domain.
Default
All ports of an ESRP domain have ELRP transmission enabled.
Usage Guidelines
This command allows you to configure the ports in your network that might experience loops, such as ports that connect to master, slave, or ESRP-aware switches, to receive ELRP packets. You do not need to send ELRP packets to host ports.
The following command enables ELRP packet transmission for slot 2, ports 3-5 on ESRP domain esrp1:
configure esrp esrp1 add elrp-poll ports 2:3-2:5
This command was first available in ExtremeXOS 11.1.
Platform Availability
